RE: Multilight Promgramming HELP!
Hi Gary,
I'm using a Powerbox SRS.
Anyway, I just reset everything and hooked it up on the throttle channel. As I slowly move through the ratchet, I only see the following 3 'programs' indicated by the light sequence....
Ch 1 - 4 flash
Ch 1 - 4 flash and 5 & 6 come on solid
Ch 1 - 4 flash and 5 - 8 come on solid
None of which seem to be what I need?
The instructions seem to list 7 programs?!??! Why do they make it so hard [:@]
As you say, I need the Pos'n flasher (3), navi lights (3) and headlights (2) program but I can't get to it!! I assume I get to these programs as explained on Page 2 step 1, throttle to -100%, hold the 2 buttons down, wait for the lights to chase and then move the throttle stick until I see the right channel?
If successful, how would the correct program display lights wise? 1-3 flashing, 4-6 on solid, 7 & 8?? (solid)
Thanks for the help so far!
Rgds,
Mark
