RE: #4 ignition module of DLE20
My fault with the #4 is that it has too much advance change. You have to make the full advance up around 34 degrees so that the "no advance" portion will still be before TDC and not after TDC. On the DLE 20 this is easily done by just centering the sensor on the casting seam of the crankcase.
