RCU Forums - View Single Post - Engine mounting and pushrod setup
Old 05-06-2012 | 06:29 PM
bigtim
My Feedback: (13)
Default RE: Engine mounting and pushrod setup
as for the pushrods don't use full threaded rods they can break over time, like your senior modelers advised you,
if you need to install another mount just pop out the blind nuts in the back of the firewall and epoxy some wood in the holes then just re-drill the holes for the new mount there easy to do if there is already existing holes drilled
