Some have a dip switch or interface setting for digital servo mode (some even use even faster 720us center pulse versus standard 1520us center pulse servos).
If you're using a modern gyro that can be set, you need to make sure that its set correctly for the servo you're using.
But as they say on Mythbusters, that gyros can't use digital servos is a myth thats BUSTED
