RCU Forums - View Single Post - REFERENCE SETTING K-170-F
Old 05-08-2012 | 05:37 AM
passagealanglaise
Default REFERENCE SETTING K-170-F
KINGTECH K170-F<span style="white-space: pre; " class="Apple-tab-span"> </span><div><span style="white-spacere" class="Apple-tab-span"> </span></div><div>Factory Menu Start :
</div><div>Auto +2<span style="white-spacere" class="Apple-tab-span"> </span></div><div>Pump Start Ramp<span style="white-spacere" class="Apple-tab-span"> </span>5</div><div>Glow Power<span style="white-spacere" class="Apple-tab-span"> </span>7,4V</div><div>Low Batt<span style="white-spacere" class="Apple-tab-span"> </span>7V</div><div>Start Power Ignit<span style="white-spacere" class="Apple-tab-span"> </span>150</div><div>Starter Power Fuel Ramp<span style="white-spacere" class="Apple-tab-span"> </span>150</div><div>RPM 100% Starter<span style="white-spacere" class="Apple-tab-span"> </span>16000</div><div>RPM Stop<span style="white-spacere" class="Apple-tab-span"> </span>19000</div><div>RPM Reconnect<span style="white-spacere" class="Apple-tab-span"> </span>18000</div><div>RPM Ignition<span style="white-spacere" class="Apple-tab-span"> </span>5000</div><div>Pump PW Ignition<span style="white-spacere" class="Apple-tab-span"> </span>18</div><div>Engine Min Flow<span style="white-spacere" class="Apple-tab-span"> </span>30%</div><div>EGT End<span style="white-spacere" class="Apple-tab-span"> </span>120&deg;C</div><div>RPM Preheat K<span style="white-spacere" class="Apple-tab-span"> </span>5000</div><div>RPM Fuel Ramp<span style="white-spacere" class="Apple-tab-span"> </span>5000</div><div>Preheat Fuel<span style="white-spacere" class="Apple-tab-span"> </span>45%</div><div>Ignit Time Out<span style="white-spacere" class="Apple-tab-span"> </span>27s</div><div>Start Mode<span style="white-spacere" class="Apple-tab-span"> </span>AUTO KERO
<div>Factory Menu Run<span style="white-spacere" class="Apple-tab-span"> </span>:</div><div><span style="white-spacere" class="Apple-tab-span"> </span></div><div>Full Power<span style="white-spacere" class="Apple-tab-span"> </span>123000</div><div>Idle SPeed<span style="white-spacere" class="Apple-tab-span"> </span>34000</div><div>Stop Peed<span style="white-spacere" class="Apple-tab-span"> </span>20000</div><div>Start Min<span style="white-spacere" class="Apple-tab-span"> </span>100&deg;c</div><div>Max temp<span style="white-spacere" class="Apple-tab-span"> </span>840&deg;C</div><div>ACC DELAY<span style="white-spacere" class="Apple-tab-span"> </span>7 (<span style="background-color: rgb(251, 252, 255); font-family: Verdana, Arial; font-size: 13px; ">possible without any problems to low as 4, even lower depending the elevation)</span></div><div>DEC DELAY<span style="white-spacere" class="Apple-tab-span"> </span>4</div><div>Stability Delay<span style="white-spacere" class="Apple-tab-span"> </span>100</div><div>Pump Limit<span style="white-spacere" class="Apple-tab-span"> </span>600
Review Data :
<div>
Menu Start :
</div><div>Auto +2<span style="white-spacere" class="Apple-tab-span"> </span></div><div>Pump Start Ramp<span style="white-spacere" class="Apple-tab-span"> </span>5</div><div>Glow Power<span style="white-spacere" class="Apple-tab-span"> </span>7,4V</div><div>Low Batt<span style="white-spacere" class="Apple-tab-span"> </span>7V</div><div>Start Power Ignit<span style="white-spacere" class="Apple-tab-span"> </span>150</div><div>Starter Power Fuel Ramp<span style="white-spacere" class="Apple-tab-span"> </span>150</div><div>RPM 100% Starter<span style="white-spacere" class="Apple-tab-span"> </span>15000</div><div>RPM Stop<span style="white-spacere" class="Apple-tab-span"> </span>20000</div><div>RPM Reconnect<span style="white-spacere" class="Apple-tab-span"> </span>19000</div><div>RPM Ignition<span style="white-spacere" class="Apple-tab-span"> </span>3000</div><div>Pump PW Ignition<span style="white-spacere" class="Apple-tab-span"> </span>17</div><div>Engine Min Flow<span style="white-spacere" class="Apple-tab-span"> </span>30%</div><div>EGT End<span style="white-spacere" class="Apple-tab-span"> </span>120&deg;C</div><div>RPM Preheat K<span style="white-spacere" class="Apple-tab-span"> </span>5000</div><div>RPM Fuel Ramp<span style="white-spacere" class="Apple-tab-span"> </span>6000</div><div>Preheat Fuel<span style="white-spacere" class="Apple-tab-span"> </span>30%</div><div>Ignit Time Out<span style="white-spacere" class="Apple-tab-span"> </span>27s</div>Start Mode<span style="white-spacere" class="Apple-tab-span"> </span>AUTO KERO
<div>Factory Menu Run<span style="white-spacere" class="Apple-tab-span"> </span>:</div><div><span style="white-spacere" class="Apple-tab-span"> </span></div><div>Full Power<span style="white-spacere" class="Apple-tab-span"> </span>123000</div><div>Idle SPeed<span style="white-spacere" class="Apple-tab-span"> </span>34000</div><div>Stop SPeed<span style="white-spacere" class="Apple-tab-span"> </span>20000</div><div>Start Min<span style="white-spacere" class="Apple-tab-span"> </span>100&deg;c</div><div>Max temp<span style="white-spacere" class="Apple-tab-span"> </span>840&deg;C</div><div>ACC DELAY <span style="white-spacere" class="Apple-tab-span"> </span>4</div><div>DEC DELAY<span style="white-spacere" class="Apple-tab-span"> </span>4</div><div>Stability Delay<span style="white-spacere" class="Apple-tab-span"> </span>100</div>Pump Limit<span style="white-spacere" class="Apple-tab-span"> </span>600
</div></div>
