RE: Balsa USA 1/4 Scale Nieuport 28 Build
I didn't get a lot accomplished this weekend but I did get the most time consuming part done. For me sheeting the wings takes a bit of time. Because I am using regular wood glue I must clamp the parts up and let them dry. For the top wings, this process is complete. I need to add the cap strips to the left wing, add the leading edge, then sand the leading edges of both wing halves. After that the halves will be joined into one piece.
Then onto the lower wing.
I compared the two wing panels but stacking them on each other and they match perfect. I am glad I caught the mismatch in the plans.
SunDevilPilot
