RE: No lift(after long headache) 450 Clone
Your motor was probably fine and your collective is reversed. You need to find a way to reverse your pitch channel.
Do what I said with the throttle hold, if I'm correct you'll notice that as you move the stick up the swash plate is moving down instead.
