RCU Forums - View Single Post - Sterling 48
Thread: Sterling 48
Old 05-10-2012 | 05:15 PM
  #70
All Day Dan's Avatar
All Day Dan
Default RE: Sterling 48
The flying bridge sides and windshield frames were cut from 1/16 plywood. After a couple of tries at a dry assembly it became apparent that the structure was much too flimsy. I cut duplicates of the frames from some 3/32 plywood and doubled up the forward portion of the sides with some 1/16 plywood. After I got a good dry fit of the assembly, I ran a bead of zap-a-gap down the windshield joints. I then reinforced the joints at the on the rear surface and used a mixture of finishing resin and balloons to get a better fit to the cabin roof. The sides and the windshield are not assembled at this time. They have to be removed to paint the cabin roof and sides. Dan.
ID:	1761344   Click image for larger version
ID:	1761345   Click image for larger version
ID:	1761346   Click image for larger version
ID:	1761347   Click image for larger version
ID:	1761348   Click image for larger version
ID:	1761349   Click image for larger version
