Hello All
I was at my LHS and tried a sim. My luck I fly horible. So before trying to fly my champ for the first time Iwant some sim time. Of course you cannot use the provided controller with a sim. I also know that I want a futaba radio because most of the info for max range on the differant types of radios say they have the longest range. My opinion is if I get a radio that I can fly my plane farther than I can see it then it will be safer when I go behind an object while flying. More wave= less chance of signal loss.
So here is my problem.Do I get another spektrum type radio, one thathas buddy port,knowing that I will be getting a futaba in the future? I could get a FMradio from futaba and put in the spektrum module and get the fasst one so I can use the same radio for both my park flyers and the longer range ones. I could also forget about the spektrum radio and buy the new futaba 7 or 8 chanel I want, using it with the sim. IfI go this route I use the provided controller for my BNF aircraft I have now.
Any advice is what I need so I can make up my mind on this.
Thanks all
TF
