RCU Forums - View Single Post - Evolution 58GX ignition setup question
Old 05-16-2012 | 06:19 AM
RBSteffey123's Avatar
RBSteffey123
My Feedback: (57)
Default Evolution 58GX ignition setup question
<p class="MsoNormal"><span class="apple-converted-space"><span style="font-family: Arial, sans-serif; ">I have an Evolution 58GX with the MVVS G2 ignition system and I need some feedback from anyone can help. <o></o></span></span></p><p class="MsoNormal"><span class="apple-converted-space"><span style="font-family: Arial, sans-serif; ">I setup the throttle and choke servo into the Smart-Fly EQ6 Power Expander board that has an optical kill module. The MVVS ignition has features to &ldquo;stop&rdquo; the engine if firing backwards at startup and an auto-choke feature, input power has 7.4 volt 2600Mah Fromeco. <o></o></span></span></p><p class="MsoNormal"><span class="apple-converted-space"><span style="font-family: Arial, sans-serif; ">Once setup, I can start the engine easily (Manual choke) and leaving ignition on after closed choke &ldquo;pop&rdquo;. If you turn ignition off and hand prop, then turn ignition on to start, it makes a loud &ldquo;POP&rdquo; igniting fuel in cylinder (So leaving ignition on going from closed choke to open position will prevent premature ignition). <o></o></span></span></p><p class="MsoNormal"><span class="apple-converted-space"><span style="font-family: Arial, sans-serif; ">The engine sounds good on the ground (Tach&rsquo;s at 6400 rpm) on the rich side, but prefer to not run lean. High throttle pulls like hell, and the low idle purrs at 1600 with 24x10 Mejlik CF prop. Carb settings are 1 &frac34; out high needle, 1 &frac34; out low needle <o></o></span></span></p><p class="MsoNormal"><span class="apple-converted-space"><span style="font-family: Arial, sans-serif; ">Once air-born, I fly for a few minutes and the low idle changes and the rpm's start increasing and the gurgle and popping noise when idle sounds like the choke is partially closed? The rpm&rsquo;s increase and I need to cut ignition or trim down to land .<o></o></span></span></p><p class="MsoNormal"><span class="apple-converted-space"><span style="font-family: Arial, sans-serif; ">Does this MVVS G2 ignition require programming the choke if not using the "Auto-Choke" feature? I cannot find the &ldquo;Programming&rdquo; plug, will the &ldquo;Bind&rdquo; plug work from my AR8000 receiver?<o></o></span></span></p><p class="MsoNormal"><span class="apple-converted-space"><span style="font-family: Arial, sans-serif; ">I have a Fromeco 2600 2s plugged in the smart-fly ignition module? I am also using HiTec digitals on the throttle &amp; choke, going to change them to my older but very reliable and strong JR analog metal gear servos.<o></o></span></span></p><p class="MsoNormal"><span class="apple-converted-space"><span style="font-family: Arial, sans-serif; ">Should I not use the Smart-Fly optical, and just plug ignition to 2S 7.4 fromeco directly?</span></span></p><p class="MsoNormal"><span class="apple-converted-space"><span style="font-family: Arial, sans-serif; ">Any suggestions would be appreciated.<o></o></span></span></p><p class="MsoNormal"><span class="apple-converted-space"><span style="font-family: Arial, sans-serif; "></span></span></p><p class="MsoNormal"><span class="apple-converted-space"><span style="font-family: Arial, sans-serif; ">Rick</span></span></p>
