I was wondering if it is possible to set up my plane as a normal wing with functional ailerons, and rudders but, have the thrust vector setup independent of each other.My point would be so when I use the ailerons the the twin vectors will move opposite of each other but when using elevator, and rudder they will work together.
How many channels will I have to set aside for this operation if possible.
I only have my Rookie set up with elevator, and rudder movement. When I use aileron there is no movement with the thrust vector. I was hoping to set up the Mig a little different considering it has twin thrust vectors.
Thank you
Ivan
