RE: Looking For Hand Tool Must Haves
OLFA Rotary Circle Cutter.....cutting clean circles is handy, a miter box for the razersaw is a plus( cutting right angles/45 degree angles)...an airbrush/pump setcan comebecalled a must have( cheapsets out there work fine for camo).....lots of different grit sand paper,shoegloo is a must( ifno other glue will work, it will),a candleto make plastic workable/ bendable, a butain torch for shrink sleeves.....a good sodtering iron with different tips.If you you do not haveaccess to c4, a BFH will get er done as well.
