ORIGINAL: mustclime
OLFA Rotary Circle Cutter.....cutting clean circles is handy, a miter box for the razersaw is a plus( cutting right angles/45 degree angles)...an airbrush/pump set can come be called a must have( cheap sets out there work fine for camo).....lots of different grit sand paper, shoe gloo is a must( if no other glue will work, it will), a candle to make plastic workable/ bendable, a butain torch for shrink sleeves.....a good sodtering iron with different tips. If you you do not have access to c4, a BFH will get er done as well.
Sounds like your wanting to own a construction company!
~ Jeff
