RE: Spektrum/JR CF receivers?
From spektrum flight log instruction sheet.
Guidelines for DSMX
• Holds—Holds are unacceptable. If a hold occurs, please investigate and correct
the issue before next flight.
• Frames—<100- In conventional models during a 10 minute flight, frames
should typically be less than 100 on all receivers.
• Fades—Use Fades for comparison only. All attached receivers should have
similar Fades. If not, investigate poorly performing receivers (location, antenna
orientation, etc) and correct.
I will normally see 999 fades on one or two receivers in the Ultra using DSMX. However, I am comfortable with this as frame losses are usually in the zero to 10 range.
