RCU Forums - View Single Post - Spectrum receivers
Old 05-18-2012 | 09:20 AM
  #61
opjose's Avatar
opjose
Default RE: Spectrum receivers
ORIGINAL: ATVAlliance
While I dont know enough to say that the 6ch Orange RX is or isnt the same as the board used in the ''suspect'' AR6200's I own. I can say that the Orange RX 6ch only have a single antanae lead (short red one). The ''suspect'' 6200's have dual antane on the main RX, as well as the Sat RX too. Looks in every way the same as an original one. Only thing, the ones I bought from oomodel came in a clear plastic zippy bag and no documenatation whatsoever.
Any way you could post a close picture of the circuit board w/o destroying yours?
Preferably of the side with the SMD's, not the trace side.
I'd love to compare them to both the Orange RX which I highly doubt are the same but who knows... and to the real 6200's.
When I've compared the Orange 6CH RX's to the black and silver clone RX's I purchased at an LHS I found the boards to be identical with identical traces. Only the types of capacitors used varied a bit.
If anyone is interest I can post pics...
The Orange had only one antenna, but the black and silver clone had two, so after I had the problem with the 6CH I also tried soldering on the second antenna to see if this improved matters. The support circuitry is there for BOTH antennas on the Orange RX's.
