RCU Forums - View Single Post - Spectrum receivers
Old 05-18-2012 | 10:34 AM
  #70
opjose's Avatar
opjose
Default RE: Spectrum receivers
ORIGINAL: grimbeaver
Let me circle back. Spektrum marketing/packaging tends to imply that satellite rx are required for the average user to reliably use their rx.
No, it implies that the satellite RX provides for better multipath rejection and less chance of polar dropouts that other RX's can experience with a single antenna/node.
This is true.
This is compounded by the fact that they designed the AR8000 (and others I'm guessing) to require one to work.
Try one sometime without the satellite and you'll see it works fine, but it is not optimal. For best reception use the satellite as it is designed and supplied.
As a very loose analogy: Your car will drive just fine without the spare tire too, but your better off with it in the trunk.
So one of two things is true, either the rx itself is an inferior design which needs a satellite to function reliably for the average user,
And there's that specious implication again...that some how multiple nodes equates to "inferior" when the exact opposite is true.... it is a SUPERIOR technique, Futaba's and Airtronics choice NOT to use one not-with-standing. The latter two vendors are relying upon other mechanism to even the playing field vis-a-vis marketing claims and product tests.
I'm not saying which one is true, personally I'd really like to know which one it is.
Here it is:
Multiple reception paths are almost always better than single ones.
Multiple reception paths help overcome the polarized nature of antenna transmission and reception patterns.
http://en.wikipedia.org/wiki/Antenna_diversity
Spektrum/JR includes the satellite on many RX's and makes it optional on others.
You DO NOT HAVE TO BUY the satellite if it is not included, but your assured better performance/reception if you do.
I'd advise people not to sweat it on the smaller planes, but maybe opt for the satellite options on the larger ones, and/or planes with a lot of internal wiring/plumbing...
or it's just marketing bs to get you to buy more stuff from them. I'm not saying which one is true
Futaba came out with their nice S-Bus system... is it marketing BS to get you to buy more stuff from them?
Some might argue it is... others may tell you that this is a superior way to hook up multiple servos on larger planes.
I agree with the latter, but those who argue the former, probably don't have the larger planes that may take advantage of it so they can't see the rational.
