RCU Forums - View Single Post - torment steering issues...
Old 05-20-2012 | 03:42 PM
nitrosportsandrunner's Avatar
Default torment steering issues...
my ecx torment has a MG996R steering servo...which has plenty of runt.
The problem is that the "C" ring on the bell crank gets weak. the ring is basically the servo saver. But its weak and now the wheels wont center...even tho the servo does.
I have replaced this ring once already!
Im considering simply glueing the 2 halves of the bell crank and the "C" ring all together...basically removing the servo saver. Im not to worried about the servo being damaged, as its metal geared and if it should break its cheap to replace. But I do worry about the steering hub, arm and servo arm.
Thoughts? Do I have any other option? Having a SCT that doesnt center its wheels is a huge pain to drive!
