RCU Forums - View Single Post - engine bearing puller
Old 05-20-2012 | 05:55 PM
blw's Avatar
blw
Default RE: engine bearing puller
ORIGINAL: jaka
Hi!
Pullers should not be used when replacing bearings in an aluminium case! If done that way you will damage/wear the bearing surface and the bearing will sooner or later come loose.
Only heat should be used! Either an owen or a propane torch!
It doesn't matter what happens to the bearings if that were true. You use a puller to get the drive washer off. Anyway, aren't those bearings getting tossed when you get them out?
