ORIGINAL: rcpattern
. . <snip>.. .
I think the bigger issue is that we need a significant change to the Sportsman pattern. Actually, not a change, but go back to a mid 1990's sequence and leave it alone forever. The idea of Sportsman is to introduce new people to pattern, and it should be done in a way that doesn't require a high end pattern plane. I see no reason to ever change the Sporstman pattern. If you can't be competitive with a .40 size sport plane, then there is something wrong with the pattern.
Arch
+11
