RCU Forums - View Single Post - reed valve material
Old 09-03-2003 | 12:12 AM
av8tor1977's Avatar
av8tor1977
Default reed valve material
I wonder if the disc material itself from a "floppy disk" would make good reed material. The problem with metal reeds is that if they fatigue and break, it's going to hurt the engine; often "big time". Stainless steel is probably best if you're going to use metal.
What all did you do to the engine re: porting?
av8tor
