RCU Forums - View Single Post - Problems with K&B .61 with remote needle valve
Old 05-28-2012 | 10:14 AM
Ozzy37
Default Problems with K&B .61 with remote needle valve
Hello all,
Got a problem with a K&B .61 with remote needle valve. Cannot get the fuel to feed past the needle valve into the carb. Have taken the needle valve off and cleaned it and also blew compressed air through the housing. Did the same thing with the carb, but I'm still having the same problems. This is the .61 that has the brass mixture disc on the side of the carb. I've checked the tank and the fuel lines for leaks and have not found any. Does anyone have any idea what the problem could be?
Oz
