Props
Don`t know the technical stuff quite yet so I will do my best. I have A Dynam Hawk that I am installing the #1 upgrade from Killerplanes. My question is How the heck does the prop fit on the motor shaft? Got a card of different washers and simle instructions and it is obvious where it goes on the prop and that it seems to be a compression fit between the prop hub and the motor shaft.So what is the trick? Cause none of the washers seem to be a fit. They all fit in the hub with a slight snap. However the shaft is a different story. Do you somehow strech the small one? Help me out here! THANX!</p>
