ORIGINAL: FlyingGatsby
Okay, I see. How much alcohol should I mix in?
You shouldn't dilute more than 30%by volume.
Whatever you add to epoxy -thinning agents, c. silica, flocked fiberglass, wood dust, etc - ALWAYSmix the epoxy well first and let it set a half-minute (longer for the30minute &longer hardeners)to link before adding your adulterations. You will get much better results.
