Blake
If you will go to the Trenton rc flyers website and look at the Gator Flea article it shows formers and 1/8 sheet planking top round deck which should be great for the Compensator, sometimes little brother "Gator Flea" may have a better idea. After sanding to shape you will have between 1/16 and 3/32 which should hold up to everyday handling of the model around flight line. You could design a foam deck and sheet but the planking idea maybe easier. Did the kit come with orginal diamond stab or a symmetrical one like Zimpro did when Dennis had Compensators available?
Tim
http://www.trentonrcflyers.com/patte.../gatorflea.pdf
<br type="_moz" />
