RE: Down Elevater to fly level?
How to measure the thrust line? That's not easy. Props often have runout. They often aren't square to the crank. Sometimes thrust washers aren't. It's usually more accurate to use a thin flat stick with a hole in it. Some incident meters can measure 90* things like props.
The best way to judge the thrust line is to simply fly the plane when you've got an operational plane as your subject.
