Eflite T-34 PTS Glitching
Ithought Iwas imagining things last timeI flew the plane, thought maybe it was the wind, so today Iwent out and flew it again, got 3 flights going and it flew fine, third linding saw a little rough, nosed in and cracked the paint on the cowl, but otherwise the plane was OK. Ichecked the pack, and everything looked fine, and Ilined it up and took off for one last flight. After a few minutes and some nice passes I went to pull up and it kept wanting to drop, gave it full throttle and it still wanted to drop and eventually I had full up elevator before it started to climb, The plane was not very responsive, and felt like I was going to lose it, so brought it around to land, saw it was going to hit the fence gave full throttle and it didn't respond as quickly as it used to, but did kick in and I was able to clear the fence and bring it around once more, but it was so flakey that Ihad a really bad nose in flip over landing that broek the firewall and the hold down tabs on the wings.
What would be causing this wierd behavior? Iam using a DX8 radio with all stock equipment. Using GenAce 3300 packs and the power was good, voltage was fine, Ihave an alarm hooked in the plane that beeps loud enough that I can hear it with the plane at a good distance. The radio voltage was 4.9 volts. Ichecked the controls once it was down and it looked like my up elevator was a little less than I could remember, but after looking at the setup, there is no way it would have changed.
The plane is easily repaired, just need to cut a new firewall and upper and lower plywood box pieces and glue it together, and glue the wing tabs back on. Could have been much worse had I hit the fence, that would have busted the plane far more than a cracked FW and broken tab. I'm more concerned about why it acted up since I use the same radio for my gas powered Dewey and if its the radio, I dont want to have that one glitch as it would make a bigger bang when it hits the ground, it has at least 5 pounds more on it than the T-34.
