Setting a YS PUMP. HELP !!!!
Hay ChuckAuger, thanks for responding. You helped me before. Thanks again. When I first started running it, I had to open the regulator 1/2 turn to make it run. Now it's loading up, so I guess I will have to start going back in with it.
How long does it take for these YS engines to settle in? I have never run one. I have run almost everything else out there for the past 18 years, but this is different.
One last thing......What process is used to set the three parts..LOW NEEDLE..HIGH NEEDLE...and REGULATOR? I think the low is about right, but wont the high needle and the regulator interact a lot with one another?? Thanks again for your help.
