RCU Forums - View Single Post - Linkage Geometry on My Electra
Old 06-03-2012 | 09:56 AM
JackD's Avatar
JackD
Default RE: Linkage Geometry on My Electra
ORIGINAL: KFX450
The stabs trailing edge is preventing the elevator from moving any further than .5 inches. Thanks jack
OK, I checked mine and it doesn't catch and I didn't do anything during construction to prevent it... But I had this happen before in other planes
I haven't tried this but I have read you can force the elevator in, hold it with some down deflection, and heat the area up with a heat gun (careful, don't burn anything!!!)
The other option is just to sand it with a sanding block. I would sand the stab trailing edge, not the elevator leading edge
One last thing, make sure there is nothing inside blocking the movement. Maybe a drop of glue or something?
let me know if any of this works. You do need the deflection.. you are going to be flying it inverted a lot!!!!! This is by far the most fun plane I've ever had
