RE: Help building first plane
you will need a computer radio that will allow you to program an "elevon" mix. Once the mix is programmed properly, the computer in the Tx will move the ailerons in opposite directions when you move the stick left / right and will move them together when the stick is moved up and down. Good luck to you, you have chosen a difficult build for your first plane, but you are in the right place to ask questions!
