Correct on the triangle except the angle is a 45.
Verne Koester
ORIGINAL: Silent-AV8R
ORIGINAL: rene69
The Aresti sequence is not the same as the last posted. First maneuver should be Double Stall Turn not a Square loop.
Regards
Rene
Looks like they re-posted the Aresti for the previous proposed sequence again. Give it some time and I'll bet the latest version will show up. [8D]
The half triangle loop with a half roll up (Fig 17). Does that basically look like a ''7''. Pull a 60 degree up line, ½ roll, push 120 degrees to upright and eit?
