Sorry, didn't catch your 120 degree push. For someone as mathematically challenged as I am, "push to level" works better. That being said, the angle is a 45. Most of the newer sequences have avoided 60 degree angles because they're too hard to judge for both the pilot and the judges. Obviously, the 6-sided loop is an exception, one of the reasons I think the 8-sided is a better choice.
Verne Koester
ORIGINAL: Silent-AV8R
ORIGINAL: VerneK
Correct on the triangle except the angle is a 45.
Verne Koester
ORIGINAL: rene69
The Aresti sequence is not the same as the last posted. First maneuver should be Double Stall Turn not a Square loop.
Regards
Rene
Looks like they re-posted the Aresti for the previous proposed sequence again. Give it some time and I'll bet the latest version will show up. [8D]
The half triangle loop with a half roll up (Fig 17). Does that basically look like a ''7''. Pull a 60 degree up line, ½ roll, push 120 degrees to upright and exit?
Then it cannot be a 120 degree push. It would be a 135 degree push back to upright/level. But I've got it now. Got twisted up recalling my 5th Grade Geometry teacher!!
