RCU Forums - View Single Post - Lanier Predator - first flight, need help
Old 09-02-2003 | 06:04 PM
Ed Smith
Default Lanier Predator - first flight, need help
From the many previous posts regarding the inaccuries of this model (Warped wings is an example) I have read that the Engine/wing/tail incidence is not that good.
The first thing I would do to solve the climbing question is to check the tail and engine incidence relative to the wing. All three should be set at 0-0. to start with. If the tail is glued in then prpbably the easiest fix is to shim the wing and/or engine.
There is little point in making other suggestions until the wing warp is corrected and the incidences are correct.
Ed S
