RCU Forums - View Single Post - Jet-Tronic Brake Valve Setup Problems
Old 06-07-2012 | 06:13 PM
Sundownee
My Feedback: (30)
Default RE: Jet-Tronic Brake Valve Setup Problems
hey guys, for those that may want to know and maybe still have some of these that are leaking and not working correctly.
I figured out the problem, they are connected properly but the problem is a decfect in the base from the manufacture.
They drilled a extra hole in which they tried to recover it with bad material with no luck causing the leak and non functioning valve.
I have two pictures here showing the problem and where the hole is to repair.
you can use JB weld or just use CA to close it up.
very easy fix, little soldering skills needed to remove the board and reapply it.
ID:	1770150   Click image for larger version
