RCU Forums - View Single Post - Noob with a plane (kinda)
Old 06-08-2012 | 03:32 AM
acdii
Default RE: Noob with a plane (kinda)
The newer 2.4 RX can be hook looped in some planes, but should be wrapped in planes that have strong vibrations, the hook loop tape will transmit the vibrations to the RX. The further back in the plane the better, but for the RX the OP has, WRAP IT!
Simply put, if you can feel vibrations with your hand where the RX is when the engine is running, so does your RX.
