RCEXL MINI TACHOMETER
My question is, can I use a RCEXL Mini Tachometer with a Zenoah electronic
ignition module? I ask this because I have one hooked up and I get a con-
tinuous cycling of the led display, from 0 to 3 or 4 thousand rpms. This is
just turning on the device. I have one hooked up to a dle ignition module
and it works just fine. When it comes on it cycles through the numbers once
and then stands steady at zero until the engine is started. Is it compatible, does
anyone have pictures of this particular setup? Thanks, Aframe2
