RE: Sig Hog Bipe Beginner
Looks really good! You said you finished the wings..........You must have got the interplane strut mount issue resolved. Just keep on swinmming-You will get her built!!
One thing you might consider on the balsa headrest. I used a soft easy to carve chunk of balsa then put a single layer of glass using polycrylic as a filler. Should have used two layers of glass there. Mine is very easy to dent. That is a wear area that my stand contacts and the headrest catches considerable abuse if i am not careful.
