RCU Forums - View Single Post - Cutting straight 90deg edges to make sheets
Old 06-10-2012 | 11:50 AM
karolh
Default RE: Cutting straight 90deg edges to make sheets
Using a long steel rule and a sharp hand held hobby knife has always worked quite well for me. Just like you I use masking tape to hold both joint edges tight together along the length of the joint, then turn the sheets over and open the joint into a V shape and run a bead of carpenter's glue along it and then close the joint and lay the sheets on a flat surface with adequate weights applied to keep them flat, wiping off all excess glue with a damp cloth.
Karol
