Flap Servo Set Up
When setting up a Flap Servo, with the Flaps Retracted should the servo be at Center and no End Pont set to prevent any further Flap movement past retraction, and when extended, you set an end point reflecting the extent you want the flaps extended; or do you set them up differnt than what I have outlined?
