RE: gorilla glue vs. epoxy
When you store the GG foaming kind you need to squeeze all of the air out of the bottle. Keep it where the temp will not go up and down to create moisture. Make sure the cap is on tight. Then, and only then, if you are lucky, it won't dry out.
