RE: Compensator Build
Thanks Crank!
Tim, thanks for the tip, but I installed the blocks before I sheeted the wing. IIRC I moved it back about 0.125", I hope that is enough. I usually like an aft CG location. The tank is on the CG, so at least it will not be a factor. If I need to , I can bend the gear to place the wheels further back... I am working on it now, and hope to start Monokoting tomorrow.
Cheers,
Blake
