ORIGINAL: DonLEmmel
Great shot of your Sbach. I've got the same color scheme and it is simply a beautiful looking plane! The alignment of your spinner and your cowl makes me curious if mine somehow got down thrust in it. Mine tends to balloon on landings. I'm told this could be from too much down thrust.
<div style="margin: 0in 0in 0pt"><span style="font-size: 9pt">Thanks Don... the color scheme certainly looks great as well as easy to see in the air.As for the alignment, I really didn’t do anything different from the docs… I just drilled at the marked location on the firewall and mounted my DLE 30 v2.My CG is behind the tube… and it’s a pinch tail heavy, but that’s where I normally set my all my planes.I didn’t notice extreme ballooning when I throttle down… but it does take it’s time to bleed air speed on landing. That just could be that the plane is streamline… or I’m just use to my late Yak.</span></div><div style="margin: 0in 0in 0pt"></div><div style="margin: 0in 0in 0pt"><span style="font-size: 9pt">What engine are you running on your Sbach?I’ll take a picture of my later spinner and cowl.</span></div>
