RCU Forums - View Single Post - gorilla glue vs. epoxy
Old 06-12-2012 | 01:23 PM
  #46
OldRookie
My Feedback: (13)
Default RE: gorilla glue vs. epoxy
ORIGINAL: Gray Beard
Relax, some products are just beyond the use of some people?? In this case I think perhaps the Gorilla glue may have out thought the user? Things like that have been know to happen.
Typical fan boy response. Are you a fan boy Gray Beard?
I have had good success with Gorilla Glue. I never said once that I had problems using the product, just that it wasn't worth the trouble to use the awful stuff. I've used it to glue parts of two MoJo 60 planes, and to laminate.
I have found that cyanoacrylates, alphetic resins, and epoxy are all generally stronger than needed for model building. My reply to the OP was intended to point out that all of the glues we use are strong enough for his use, and that polyurethane glue will work as well, but why bother? It is a pain in the azz to use.
I guess I don't care for your condescending remarks about my perceived inability to use glue properly. It is not flattering to you, and shows your ignorance. Belittling people only shows your ignorance, and not the person you felt compelled to put down.
When it gets down to it, I don't give a damn what you use for glue, but you have to realize that other people may not always share your opinion of a products worth.
Just saying
Greg
