RE: cant believe it!
Those really aren't head gaskets anyway, are they? I thought they were shims to be used or removed in order to raise or lower compression depending on what percent nitro being run in the engine. An engine run on no nitro will run on higher compression than will an engine with, say, 20% nitro fuel. In other words, as nitro content goes up, compression ratio needs to come down.
