Skymaster Hinges
Does anyone have any luck using the hinges that come with a Skymaster kit????
The ones that are knock offs of Robart hinges......
I have always used robart instead of the stock hinges.. On the BD 5 I am building the rudder hinges came glued into the rudder only.
Rather than drill them out and rebuild rudder to use robarts I just used the stock hinges...
Now that I have to rudder glued to the fin. I am seeing alot more play in the hinge pin than I am used to with Robart Hinges...
The play is a in and out movement....
Should I worry these hinges are going to wear out in 3 flights or will they be ok.....
Problem is now that it is all glued.....I dont even know what I would do to change the hinges.
Thanks for the input
Bill
