RCU Forums - View Single Post - Engine mount 'flex'
Old 06-20-2012 | 05:18 PM
Truckracer
My Feedback: (19)
Default RE: Engine mount 'flex'
ORIGINAL: ahicks
ORIGINAL: Truckracer
I wouldn't tolerate that kind of flex and don't especially care for any of the molded mounts. Hanger 9 makes a decent universal aluminum mount at a fairly good price. These have worked well for me in the past and are the same as supplied in many of their ARFs.
Yes, a flexible mount can be very hard on your muffler and airframe.
Guys, it's not like the engine is jumping around while running at all. Mine isn't moving around at all actually. I can though, grab the prop and move the engine visibly, as seen by looking at the spinner - cowl gap.
Regarding solid mounting, Dubro supplies a mount I see a few guys using - that uses rubber bushings? How is it that those mounts work, when you're suggesting a nylon mount that allows some movement will not? Not following that logic, but I could darn sure be missing something! Don't forget, we're using beam mounted engines here!
At least with the DuBro mount the engine lugs are bolted to a solid piece aluminum that doesn not flex under the engine lugs. The flex area is limited to the firewall area only and not across the whole length of the mount beam. This has to be better for the engine I would think. The DuBro mount would have to be a far cry better than the ARF supplied, almost rubber like mounts. But then, I don't really care for the DuBro mount either. Just personal preference here.
I'm only stating my opinion of the types of mounts I prefer. As always anyone is free to use whatever they see fit to use.
