Hello!
Looks great
i also used Lexan on my Ultra Flash. Perfect material, and as you say - routing of the wires is so much easier as you can actually see what is going on below the deck. When I was finished with the install I used adhesive foil to cover the lexan with, then I reinnstalled all the components.
I will be using lexan on all my future jet builds from now on!
Helihover<br type="_moz" />
