RCU Forums - View Single Post - Composite-ARF Integral, kinda build thread
Old 06-25-2012 | 07:50 PM
  #1015
VerneK
Default RE: Composite-ARF Integral, kinda build thread
Joe,
I strongly recommend the Hacker C50-14XL Comp. The non comp versions are prone to overheating resulting in magnet separation. The comp version has a built-in fan that prevents all of that. I bought two of them 8 years ago and still use them today. In fact, those are the only two electric motors I've ever had or needed. With 25C batteries, I never use or need full power.
Verne
ORIGINAL: gaRCfield
I picked the plane up this weekend - thanks Verne and Bob!
1) I am still undecided about motor selection. I want light weight and reliable. My choices are Plettenberg 25-12 Evo, Neutral F3A, and Hacker C50 (non comp). I do have a Neu 1512 that I can use as a backup if there was ever an issue with the Neu F3A, so down time would be minimal. The Pletty 25 is an 18.4 oz outrunner that meets the required specs, but I don't see a lot of field usage, nor know about service. I imagine the Hacker is reliable and I know about getting it serviced, but if the c50 is enough, why is there a comp version for $300 extra?
2) I'm working through servo selection. Not sure if I want to stay with one brand, or mix Futaba and JR for the lighted possible combination. This may depend on whether or not the 9411 will fit in the ailerons; it will br close as the lite ply is cut close to 1.5in long.
JR has a cored servo that is a direct drop-in in the stab (ds831 i think). It is inexpensive and light but so far, my favorite servos (very smooth feeling) have been coreless. That being said I have little experience with JR (821 only) and no experience with Futaba.
