Go Back  RCU Forums > RC Airplanes > Pattern Universe - RC Pattern Flying > RC Pattern Flying
 Composite-ARF Integral, kinda build thread >
Old 05-22-2014 | 09:47 PM
  #1076
Jetdesign's Avatar
My Feedback: (8)
Yes, excess down thrust is gone.
Old 05-23-2014 | 06:15 AM
  #1077
Originally Posted by Jetdesign
It looks like I missed the wing angle by quite a bit. I remember being at about 0.6deg positive to the stab but I need quite a bit of elevator to fly level and the plane really pulls to the belly in all other attitudes (climbs, dives, knife edge). At this point I'm thinking about wing adjusters until I figure out where I want things to be, but will double-check the thrust angle before making any changes.
I am really rusty after 3 days of flying before losing my plane at Nats last year. It is taking some time getting used to it and flying in general.
Your symptom statement is a bit confusing. You say you need a lot of elevator to fly level. Are you holding elevator or trimming it in? Up or down? You can't test vertical up, vertical down, and knife edge until you have the plane perfectly trimmed for hand off straight and level, and that means hands off the sticks for the full length of the box. Once you have that, you can get some useful analysis of what happens in the other attitudes.
Verne
Old 05-23-2014 | 12:48 PM
  #1078
Jetdesign's Avatar
My Feedback: (8)
OOPS - I meant it pitches to canopy Late night mistake.
Old 05-23-2014 | 12:49 PM
  #1079
Jetdesign's Avatar
My Feedback: (8)
Old 05-25-2014 | 08:54 PM
  #1080
Jetdesign's Avatar
My Feedback: (8)
So 'a ton' of elevator mix doesn't really appear to be that much when looking at the control surface. It was a lot of clicks due to the high res linkage but maybe only a few degrees of throw. I played with the CG and moving it back didn't really change that but it did feel a little nicer. Thrust line appears to be just right. I'm starting to have some better flight segments. I'll triple check things with the meters before making any changes to the wing incidence but it seems like it needs a slight adjustment to be just right. Probably won't happen before the D4 warmup but we'll see.
Old 02-18-2021 | 12:52 PM
  #1081
Does anyone have a new Belly Pan for integral to sell.
Thank you.
Old 02-20-2021 | 07:48 AM
  #1082
speedracerntrixie's Avatar
My Feedback: (29)
Thank you.
Do you have a broken one that can be repaired or missing one entirely?
Old 02-20-2021 | 08:59 AM
  #1083
Thanks for the reply. This a plane that I rarely fly and has a YS in it. These days getting a new header is impossible so Was thinking to convert it to electric so if there was a belly pan without all the cut outs could bed nice.
Behzad
Old 02-20-2021 | 09:25 AM
  #1084
My Feedback: (29)
If you don't find one I would be happy to fix the one you have.
