What do I need to program? Can I just leave the factory defaults on the timing?
Maybe.... Maybe not.... Depends on many factors. Best thing to do is to disconnect the door cylinder from the door an cycle. If the delays pre-programmed are working as desired than no additional programming needed for the sequence. Some adjustment in timing is likely however.
Todd
