ORIGINAL: apereira
So and increase in the weight limit will only result in a cost incresase of the sport, and those who can not make weight is because ussually can not or do not want to afford the right equipment, so it wil make the situation worse for those people again.
Like my friend Bryan H. says, "this is a professional category".
One thing is also true, most people who complaints about the weight rule, do not even fly FAI, some don't compete at ALL, so why making all this big deal about it?
So if you want to fly FAI, it is that way, period, if don't want to make the weight rule, there are other classes you can fly, AMA pattern is not bound to FAI, you should all try to get the weight limit off in Masters, that will be a start, but if you people have not been able to change AMA, what chances do you have with FAI??
Again you should probably tell your FAI representative,( who voted BTW for the 5Kg in the past for sure) to propose the weight change at the CIAM conference, this is the only way, and again, if you can not change AMA.........
Alejandro Pereira
To quote Ricky Bobby "With all due respect!!!"
So the first line I quoted of yours is a total contradiction. You say increasing the weight will increase the cost of the sport, but also say those that complain cannot afford the proper equipment? Doesn't make sense to me.
And I do compete, I have spoken to representatives and I still haven't gotten a single answer as to why a heavier plane is an advantage.
<br type="_moz" />
